Do these plugs look too cold? TR6
Old 06-07-2014, 05:58 PM
jayrod2's Avatar
Mods are 383 eagle forged crank, forged pistons and rods, over the radiator CAI jethot longtubes and custom true duals with h-pipe dumped, comp 1.6rrs ported LT1 heads (flow 270/190)
ported runner LT4 intake, EWP
42lb green top ford injectors
custom grind cam by alan futral 238/245
58mm BBK throttle body
all emissions stuff deleted
Developed a miss a little after I changed plugs. I floored it to 6,000 a few times and it MOSTLY cleared up. Really only does it up high in the RPM's now, but before I floored it, it would do it all over the RPM's even down low. I think I should try TR55's. Before I changed them, it had the TR5ix. Only things I have done are swapped with a good stock coil, and inspected wires at night. Didn't see anything, and coil didn't help. Plugs have about 60 miles on them.
jayrod2 is offline
Old 06-07-2014, 05:59 PM
jayrod2's Avatar
Re: Do these plugs look too cold? TR6
jayrod2 is offline
Old 06-07-2014, 08:19 PM
97WS6SCharged's Avatar
Check the gap on that one that is fouled (black). It's likely too wide for your application. You shouldn't have that kind of issue just from swapping to a plug with a heat range 1 colder. I would replace the fouled plug and double check all the gaps and then check the header temps with a heat gun at idle and at a steady 3k rpm. Could be the injectors just need a slightly different multiplier.
97WS6SCharged is offline
Old 06-07-2014, 09:22 PM
jayrod2's Avatar
I gapped them all at .45. Was that too wide? I don't have a heat gun to check header temps. The tune has been checked again. I was told it looked fine. IDK, it seems to be getting better the harder I drive. The car was sitting basically for almost 4 years, just driven once a month around the block but when I did start driving it a few weeks ago and even over the 4 years I don't remember it misfiring.
jayrod2 is offline
Old 06-07-2014, 11:30 PM
jayrod2's Avatar
I just re gapped to .35. That black was no longer. I guess the last couple of times I floored it it cleaned it off. They all looked really good. Ill see how it runs tomorrow.
jayrod2 is offline
Old 06-08-2014, 01:06 AM
Run them for a day or two and pull the plug from the hole that was previously gunked up along with one or two other plugs and see how they look. .035 may be a bit too small if you're just driving around on the street.
Old 06-08-2014, 07:55 AM
jayrod2's Avatar
Well I read .35 is a good gap for a 383, and I just checked the old plugs and they were at .35 too (I never checked them before).
jayrod2 is offline
Old 06-08-2014, 10:04 PM
Displacement isn't really a factor. It's more about compression, ignition, fuel type... that sort of thing.
Magenta_Hearts
03-29-2017 08:54 PM
markzzzz
05-08-2015 09:21 AM
greenzee28
03-26-2015 09:13 AM
Magenta_Hearts
03-25-2015 10:24 AM
armedtrigger
02-24-2015 08:30 PM
Quick Reply: Do these plugs look too cold? TR6
