Do NOT use a Purolator Oil Filter for an LT1!!!
Old Sep 30, 2005 | 10:34 AM
  #16
Flip94ta's Avatar
Re: Do NOT use a Purolator Oil Filter for an LT1!!!
Actually I think your title is a little harsh, you get the one bad oil filter that comes out after 10,000 roll off the line and you are trying to banish this product forever.
Old Sep 30, 2005 | 12:23 PM
  #17
FastZinTennessee's Avatar
Flip- I stopped using the PureOne filter a while ago. Not because it's a bad filter, and yes, it does have a high efficiency rating but that comes at a significant resistance to flow. I wanted a filter that hit a happy medium between good filtering and good flow, like everything it's a trade off. There used to be a write-up online where a guy set up a test where he could measure pressure drop across an oil filter, and the results were really interesting.
Old Sep 30, 2005 | 02:59 PM
  #18
Jason E's Avatar
Originally Posted by Flip94ta
I have been using pure-ones for six years and I sold them for 3 years, never had ANY problems with them. Take it back and have them exchange it for you. BTW the pure-one has a very high efficiency rating and I know it is a better filter than fram, acdelco and several others. I have never seen KnN's efficiency rating or mobilone. Anyone know these numbers. I think pure ones multipass efficiency is 98% per SAE standard.
I use PureOnes on both my cars, along with 10W30 Mobil 1. I love them both...and indeed, the multipass efficiency on a PureOne is 98%.
I love K&N's idea, but at $12.98 a filter versus $5.88 for a PureOne? No thanks. I got one of those cap oil wrenches for $6 for each car 3 years ago. Changing the oil on both every 4k, I think I've saved a lotta $$$ to sacrifice a little 1" end
Old Sep 30, 2005 | 03:31 PM
  #19
lt11997's Avatar
Originally Posted by Z95m6
Why not just go with Ac delcos, they are cheap and good quality
That is what I use, I also use Gm 5W30 motor oil.
Old Sep 30, 2005 | 03:57 PM
  #20
Evil Eric's Avatar
Originally Posted by Birdman7389
I have been using the pure one filters for quite a while with no problems. Sounds like a fluke.
i reccomend use of purolator filters on our engines, reccomend against anything fram produces. I once saw a demonstration that showed how the filter media in a fram oil filter can pretty much turn into mush when subjected to extreme conditions. I favor Penzoil 10w-40 in my engine. NEVER use a Havoline product. Its filtered sludge in a bottle.
Old Oct 1, 2005 | 07:58 AM
  #21
Deckstripes's Avatar
When I was a parts counter guy, we had filter school from a purolator rep. He bought one of every brand off our shelf, then cut em open in front of us, no tampering. I remember Fram and motorcraft were loaded with metal filings. AC Delcos were clean, but had a weak looking element. I've used purolator ever since.
Old Oct 1, 2005 | 02:50 PM
  #22
Jason E's Avatar
One day when I was doing an oil change on my fiance's old '93 Probe, I noticed no oil was leaking out of the filter when I was unscrewing it. Oil ALWAYS came out of it, so I knew something was up. When I got it all the way off, I turned it upside down...NOTHING came out. You could hear oil swishing, stuck inside the filter, when I would shake it back and forth. Apparently, the drainback valve or whatever in the oil filter stuck shut, causing the engine to run without an oil filter for who-knows-how-long (I did the oil on that car every 4k).
The type of filter? FRAM I only bought them because with the way the Mazda 2.0 was in that car, it was impossible to get a normal filter off without the textured coating the Frams have on the end. After that, I put a Purolator on, and sold the car shortly thereafter. That was weird...
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
