Do I need to upgrade my fuel pump?
Old Jun 14, 2003 | 11:57 AM
PROJEKT Z28's Avatar
Question Do I need to upgrade my fuel pump?
Rebuilding to 355 with 224/230 cam and P&P heads. Looking for ~350 RWHP. Do I need to change my stock fuel pump, or will I be OK?
Old Jun 14, 2003 | 02:21 PM
sssalah's Avatar
The stock fuel pump is good for around 400 fwhp, so I think it will be maxed out for your application. Better change it IMO.
Old Jun 16, 2003 | 07:43 AM
IDOXLR8's Avatar
I would just stick in a Walbro 255 lph and be done with it.
Old Jun 16, 2003 | 08:13 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Originally posted by IDOXLR8
I would just stick at Walbro 255 lph and be done with it.
easier said than done-
i have to do mine pretty soon
Old Jun 16, 2003 | 08:59 AM
Chris'SS #2152's Avatar
Re: Do I need to upgrade my fuel pump?
No, you'll need a 255lph intank pump so you can get all the fuel you'll need up top in the rpm range. I just had my 355 installed and needed a new 255 intake pump.
What heads did you go with? I just pulled 392rwhp with my setup.
Old Jun 16, 2003 | 09:09 AM
Gripenfelter's Avatar
My stock fuel pump died after 3500 pampered miles on the stroker application. I raced maybe 5 times.
Dropped in a walbro.
Old Jun 16, 2003 | 09:25 AM
IDOXLR8's Avatar
Post
Quit your whining and be done with it . Drop the tank and pop in the new pump. Yes it is that easy . Getting the tank back in is a different story.
Old Jun 18, 2003 | 05:17 PM
I think I am going to drive thru the break-in peroiod with the stock pump, then I'll see what the dyno says...If I am running lean, then I'll upgrade.
Old Jun 18, 2003 | 05:20 PM
treyZ28's Avatar
i'll let you drop it...
i'll put it back up
maybe i'll call spee-
ohh wait- i forgot
Old Jun 18, 2003 | 06:32 PM
Snoochies's Avatar
There's nothing wrong with using the stock fuel pump for now. Of course in the future you might need a new one but you should just wait until then. My feeling is that the aftermarket fuel pumps aren't as reliable as the stock AC Delco fuel pump. By the way, last week I replaced mine with a stock one instead of something "high performance".
Old Jun 18, 2003 | 07:21 PM
treyZ28's Avatar
Originally posted by Killerjello
change it......
jason- u bored?
Old Jun 19, 2003 | 07:02 AM
IDOXLR8's Avatar
i'll put it back up
ohh wait- i forgot
, sure just remember to tell them your car is an LT1 because if not they will assume it is an L98.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
