do i need the LT4 KM?
Old Jan 23, 2005 | 12:03 PM
Zack's Avatar
shorty headers , no cat, wide open borla are the mods. My car is running really rich causing the headers to glow, and I can smell all the unburnt fuel. Also, it has power loss on exceleration. I used my DriveRight CarChip to record some data, and I have up to 30 degrees of timing retard around 2k rpms while it stays around 20 degrees during idle. Would the LT4 KM fix that or is there prolly something else wrong with my car?
Old Jan 23, 2005 | 12:07 PM
DavesLT1's Avatar
Re: do i need the LT4 KM?
usually it's sounds from a noisey valve train that gives false knock. but if your exhaust is loose you can get it from there too. and, make sure you're using premium fuel. if these are fine try the KM.
Old Jan 23, 2005 | 12:17 PM
Zack's Avatar
only premium, although we only get 91 here :-/
Old Jan 23, 2005 | 12:55 PM
unvc92camarors's Avatar
91 is fine, nothing wrong with that
Old Mar 2, 2005 | 01:27 PM
Zack's Avatar
old but update-just replaced the km with an lt4 unit, and im still getting around 27 degrees of retard at idle. the gas has been in the tank 'unused' since december, so i'll prolly fill her up with some fresh gas and some seafoam in there to see if that helps..hopefully
Old Mar 2, 2005 | 01:37 PM
97BBlackZ's Avatar
I thought headers glowing was from running real lean..? Can the same thing happen for when your running rich to?
Old Mar 2, 2005 | 03:19 PM
ChevyTuffD.A.'s Avatar
Yes running rich CAN cause the headers to glow too.
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
jackpawt883
Aug 26, 2015 11:22 AM
Cbr02
Parts Wanted
Aug 21, 2015 08:16 AM
