Do i need a km?
Old Feb 27, 2005 | 05:43 PM
Nick-LT1's Avatar
Do i need a km?
I have mac mids no cats to slp loudmouth do i need the lt4 KM?
Old Feb 27, 2005 | 05:47 PM
GR8RIDE_96's Avatar
Re: Do i need a km?
definitely worth getting
Old Feb 27, 2005 | 11:52 PM
Re: Do i need a km?
Might want to add a "signature" with important info like year of the car, trans type, any major mods. Not all LT1's are "the same". For example, it your car is a 93, you can't use the LT4 KM.
Old Feb 28, 2005 | 12:56 AM
snakethis69's Avatar
Re: Do i need a km?
is KM = cam?
Old Feb 28, 2005 | 01:16 AM
Loony's Avatar
Re: Do i need a km?
Originally Posted by snakethis69
is KM = cam?
KM = Knock Module
Old Feb 28, 2005 | 02:41 AM
Brent94Z's Avatar
Super Moderator
Re: Do i need a km?
Nobody but you can say if you need it You don't know if you need it unless you scan your car with a scantool. From there determine if you have false knock. If you determine you have false knock then give the LT4 KM a shot.
Buying it with no false knock retard = a waste of money.
Old Feb 28, 2005 | 08:17 AM
1-bad-z28's Avatar
Re: Do i need a km?
i wouldn't say it would be a waste of money. They are cheap and a little piece of insurance if you were to develop a false knock
Old Feb 28, 2005 | 11:51 AM
GR8RIDE_96's Avatar
Re: Do i need a km?
agree 100%
Old Mar 5, 2005 | 08:16 PM
TransAm396's Avatar
Re: Do i need a km?
what do you do if you have a 93..with say a 383,gm847 and LT's?
Old Mar 5, 2005 | 08:39 PM
Re: Do i need a km?
the 95's can use the lt4 KM right? why cant the 93's?
Old Mar 6, 2005 | 12:52 AM
Re: Do i need a km?
The only option on a 93 is to "desensitize" the knock sensor with a resistor in the circuit... do a "search" on one of the "how to" pages. But first, the engine needs a good dyno tune to get the fuel and the timing map right.
Yes... 94 through 97 have a slot in the PCM for the knock module. The 93 does not have the slot and does not have the module.
Old Mar 6, 2005 | 12:55 AM
TransAm396's Avatar
Re: Do i need a km?
where can i get it dyno tuned..and about how much would it run me(anywhere around ct or virginia..and inbetween)
also..how much would a machineshop charge to put my motor together roughly...i have the LT1 block(std)pistons(4.030)rods(6")crank(3.750),main caps,main studs,and head studs. so im not sure whatelse will be needed just wanted a guesstimate and a name of a good respectable LT1 engine shop around here.
Old Mar 6, 2005 | 07:46 AM
Antz97ZNJ's Avatar
Re: Do i need a km?
The volume of your exhaust "might" cause some unwanted knock, for 30 bucks and a 5 minute install why not...Liked mine on my 97
