do i need guideplates?
Old Jul 13, 2008 | 02:21 PM
ascastil's Avatar
i have some edelbrock lt1 heads and was wondering if i need to put guideplates on them to install roller rockers
Old Jul 13, 2008 | 02:25 PM
cnorton's Avatar
Are the rockers self-aligning? If they are not, you need guideplates to stabilize the valve train.
mdacton's Avatar
self align rockers you don't need them
with a non self aligning you will need them and will need the correct ones.
What rockers are you going to use?
Old Jul 13, 2008 | 02:31 PM
ascastil's Avatar
proform cheapies summit website said they were self aligning and the paper that came with them says they are not for use with heads that have selfaligning rocker arms
Old Jul 13, 2008 | 02:44 PM
cnorton's Avatar
It appears that you have a choice to make. You may decide to ask for a refund from Summit based on the fact that the product was misrepresented or you might well decide to locate a set of guide plates that are designed for an LT1 head.
Isky adjustable guide plates have worked well for me and I've seen reference to another brand that will work as well. There have been reports of problems with the guide plates marketed by GM in the past.
Good luck.
wytblur
Oct 29, 2003 08:01 AM
onebadponcho
Oct 20, 2003 01:44 AM
MattysTA
Oct 5, 2003 08:53 AM
94formulabz
Aug 27, 2003 03:43 AM
94formulabz
Aug 15, 2003 08:50 PM
