do i need to degree my cam?
Old May 20, 2008 | 07:30 PM
  #16
LOW-LIFE's Avatar
a higher stall will "slip" more till it hits that RPM allowing you to take better advantage of the bigger cam and its longer duration over stock. but when it locks up it is the same.
Old May 20, 2008 | 10:59 PM
  #17
dubbsix's Avatar
Originally Posted by BUBBA
If your pistons are TDC the valve should not fall far. Make sure you get the correct spring compresser--one that fits underneath at the firewall. I believe Sears has one, but check with the site before you buy. Make sure you have valve stem seals if yours are shot. Check all of push rods for straightness (roll each on glass surface). Take your time. JMHO
Thanks. Im planning on buying a good one from sears or jegs. Just depends...
Old May 20, 2008 | 11:02 PM
  #18
dubbsix's Avatar
Is that more desireable for driveability or just flat out drag? The car wont see much track time .. more just street driving.
Old May 20, 2008 | 11:08 PM
  #19
SS MPSTR's Avatar
really no benefit of a higher stall on a car that is 99.9% street driven or a daily driver in traffic IMO. driving around in the stall wears it prematurely due to the heat it generates.
wrt degreeing your cam - I would, regardless of application. I just think it's conscientious practice.
Old May 21, 2008 | 12:09 AM
  #20
dubbsix's Avatar
Thanks for the input. I will have to read up on how to actually degree it. Managed to get the intake removed today. Going pretty smooth so far.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Apr 12, 2015 07:42 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
