Do I need a bigger cam?
Old Aug 8, 2003 | 10:03 PM
Rodrigues's Avatar
I think I might be in need of a bigger cam to help take advantage of my ported heads...
I was thinking about trying this new 233/239 that XE started to make. What do you guys think?
lift Intake Exhaust
.050 36.5 23/0
.100 62.9 48.1
.150 93.3 71
.200 131.7 90.5
.250 163.1 113.6
.300 185.6 126.2
.350 215.7 137.8
.400 234.5 149
.450 248.7 163.6
.500 257.7 172.5
.550 265.1 181.6
.600 271.1 184.2
I currently have the xe 224/230 and only ran 109.27 mph at the track (12.98, had a bad clutch though)
Old Aug 9, 2003 | 09:04 AM
Josh-'04 GTO's Avatar
Has this combination been tuned on a dyno?
Old Aug 9, 2003 | 03:33 PM
Rodrigues's Avatar
I have a fairly good tune in it right now... I have played with the tuning and I dont think its the problem. It had been scanned, etc.
Old Aug 9, 2003 | 04:43 PM
I'm talking about wideband A/F ratio monitoring on a dyno....you playing around with the program is not the same thing!
Old Aug 9, 2003 | 04:48 PM
96z's Avatar
96z
Whats the lift on the cam you have right now?
Rodrigues's Avatar
i had it dynoed, and they did not hook up a wideband, it produced 308.3 rwhp @ 5500 rpm, 299.1 rwtq @ 5250 rpm. The torque dropped pretty hard after 5400, but it had an extremely strait torque curve. This was done on a mustang dyno btw.
Old Aug 9, 2003 | 04:51 PM
Rodrigues's Avatar
Comp Cams 224XL Camshaft 224/230 duration @ .050", 536"/.544" lift with 1.6 rockers.
Old Aug 9, 2003 | 05:00 PM
96z's Avatar
96z
Were the flow numbers verified? False flow numbers are a sure cause for low dyno numbers...
With no tuning though very low numbers are possible...get it tuned!
Old Aug 9, 2003 | 06:20 PM
I've seen cars with alot of work done pick up near 100 horsepower over a stock tune.... enough said.
Old Aug 9, 2003 | 09:46 PM
Rodrigues's Avatar
Should I just buy my own wideband and rent a dyno?
Old Aug 9, 2003 | 09:51 PM
Timberwolf's Avatar
I don't know how many times I've told him to have it dyno tuned He likes to throw money at parts rather than solutions lol
Can't afford a dyno tune but he can afford to replace the cam, AGAIN!
Old Aug 9, 2003 | 09:53 PM
Rodrigues's Avatar
Detroit speedworks wants $600 for a dynotune, im not paying that much!
Old Aug 9, 2003 | 10:05 PM
Timberwolf's Avatar
ok, so go buy a $250 cam, $150 in gaskets, a $400 wideband o2 sensor and do it yourself makes much more fiscal sense
dboone2172
May 16, 2015 07:45 PM
thenewkid
Apr 12, 2015 07:42 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Potent77
Apr 1, 2015 12:45 AM
