Do i have to plug these bolts?
Old Oct 5, 2004 | 08:37 AM
brad20653's Avatar
Took air pump off, left everything else hanging there while i find a bolt to plug tha manifolds. Will this cause any problems idling or anything with the holes just open and not plugged?
Old Oct 5, 2004 | 10:14 AM
Type_O_Negative_1320's Avatar
Re: Do i have to plug these bolts?
You'll have the exhaust leak from hell if you don't plug those holes. Either weld them shut or find some bolts to plug them up with...don't go driving it that way.
Old Oct 5, 2004 | 11:13 AM
IrocSS85's Avatar
I just used some plastic caps that fit into the rubber hoses till I put on my headers. even with the one way valves still on the mann.s, it still leaked exh. you'll have to plug them with something.
chris
Old Oct 5, 2004 | 11:53 AM
WS Sick's Avatar
Yeah bad idea to drive with them open, will give fooled O2 sensor readings and the car will run like A$$.
Old Oct 5, 2004 | 01:04 PM
What year is your car? Many have used an M22 oil drain plug (single-cat cars) or an M18 (dual-cat cars). Even though the threads are not metric, at least on the single-cat cars, these plugs seem to work well.
The holes MUST be plugged before you run the engine.
Old Oct 5, 2004 | 01:08 PM
brad20653's Avatar
Ok in away im glad because I drove it and let it idle and it sounds like the engine is falling out rocking around very rough.
Old Oct 5, 2004 | 07:33 PM
brad20653's Avatar
I can get the bolts out of the manifolds, can i just jbweld them shut and put a cap on it???
Old Oct 5, 2004 | 08:31 PM
brad20653's Avatar
Will using caps on it be ok or it must come off?
Old Oct 5, 2004 | 10:47 PM
Follow Injuneer's advice and try to type your thoughts in coherent/understandable sentences.
Old Oct 5, 2004 | 11:30 PM
Z95m6's Avatar
Old Oct 6, 2004 | 08:12 AM
brad20653's Avatar
Sorry thought you was intelligent enough to understand "is it ok to use jbweld and cap it".
Old Oct 6, 2004 | 08:31 AM
WS Sick's Avatar
This was your hard one to understand, please keep a light additude, they were only having fun with ya.
JB weld will burn out in a week.
Old Oct 6, 2004 | 08:44 AM
brad20653's Avatar
Yeah your right im sorry, I have nine kids running around here and I was trying to type fast.
Old Oct 6, 2004 | 01:16 PM
Z28SORR's Avatar
It's been a while, but you used to be able to get brass plugs from the hardware store.
Old Oct 7, 2004 | 01:34 AM
Lower's Avatar
I couldn't get my tubing off of the manifolds either, and I tried everything. For a temp fix, I took some of the tubing down to a local hardware store, and bought huge screws that fit into the tubing. I then put high temp gasket maker all over the threads, and screwed it into the tubing after having cut the tubing at the manifold bung. I then gooped more gasket maker around the screws, and I was fine until I came up with a solution.
Unfortunately, my solution wasn't any sexier -I took 1.5 inch bolts that wouldn't quite fit into the tubing, and then ground about .5 inch of the tip end down, so the bolt would then fit into the tubing. I then coated it with hightemp gasket maker, placed it into the hole, and then rammed it all the way home, so just the bolt head is showing. Probably not the best fix, but it did work.
