Do I have an ODBI or OBDII?
Old Dec 26, 2003 | 12:48 AM
95BlackTA's Avatar
Sorry for stupid question..but I have a 95 TA with single cat(2 O2's)...and the plug under the steering wheel. Can you tell me which one I have, or do you need to know what exactly the plug looks like?
Also, If its OBDII, I found some scanners on ebay for liek 50 bucks that shows the codes only. How much more are the scanners that will show you what all is wrong with your car, like why its running rich and stuff(if those exist)
Old Dec 26, 2003 | 02:18 AM
carlos64030's Avatar
1996 + cars...OBD2
Old Dec 26, 2003 | 02:28 AM
Antz97ZNJ's Avatar
u have obd 1
Old Dec 26, 2003 | 02:38 AM
Bad AZz Z28's Avatar
OBD 1 and vented opti, 95 is probably the nicest year to start with for an LT1 FBod
Old Dec 26, 2003 | 08:37 AM
funina91ss's Avatar
Before buying a scaner make sure you don't have the OBD2 plug well that don't really matter you just have to make two jumper wires to use the scaner. http://shbox.com/1/dlc1.jpg the one on the top is the OBD1 style Plug the one on the bottom or in color is the OBD2 style plug. But you car is OBD1 no matter what plug you have.
Old Dec 26, 2003 | 08:40 AM
95 Silver TA's Avatar
You have an OBD1 PCM but a OBD2 style connector under your steering wheel.
If you already have dual cats, then your car is a 95 cali emmision car.
Thx,
Claude
Old Dec 27, 2003 | 01:08 AM
OBE1 95Z28's Avatar
As stated above, you have an OBD1 computer with an OBDII style ALDL connector. California A4 cars are dual cat, California M6 cars are single cat.
Jeff'SS
Jun 1, 2015 06:21 AM
BIGRIG
Parts Wanted
Apr 28, 2015 07:56 AM
aj2494
Mar 12, 2015 10:17 PM
twells
Oct 19, 2006 01:40 PM
thermwood1
May 11, 2003 02:46 AM
