Do I have head or crank damage?
Old Sep 23, 2004 | 02:49 PM
Kurt Crosbie's Avatar
When I start it up, I hear something knocking or tapping. After about a second, it fades away. however, I can hear rattling if I step on it at rpm's above 2k. It still has power, but it misfires sometimes.
I showed it to two local mechs. They said it was something in the crank. I talked to my best friend, also a mechanic. He says its in the valves and lifters. Who should I believe? He said its the heads for several reasons. One being that it takes a second for the tapping to stop. This means it takes the oil a second to get to the heads a neutralize the problem.
Old Sep 23, 2004 | 02:57 PM
WS Sick's Avatar
Re: Do I have head or crank damage?
If your oil pressure is pretty steady (rises with RPMS,IDles around 20 or so) I'd say its more than likely the valvetrain, it could be just rockers out of adjustment, but it could also be a lifter on the way out.
If you can feel the thump through the petal its probably a spun bearing.
Also it could be an exhaust manifold leak.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
willismoons
Feb 14, 2015 08:42 PM
