do i have to have the reluctor ring??
Old Dec 20, 2005 | 12:04 AM
red96z's Avatar
im putting the car back together and thid is causing such a delay with clearance issues with the double roller and cover
Old Dec 20, 2005 | 02:35 AM
96ta(nick)'s Avatar
Re: do i have to have the reluctor ring??
It will NOT fit with the double roller. And you will also have to have a spacer or a 94-95 hub due to the 96-97 being a different length for the CPS reluctor ring.
Old Dec 20, 2005 | 04:04 AM
sssalah's Avatar
The ring is there to monitor misfire, it will through a code when removed but can be programmed out from the PCM.
Old Dec 20, 2005 | 05:18 AM
RE AND CHERYL's Avatar
If you remove it you will have to have the CPS sensor removed from the programing or you will have the SES light on. You will also have to have a 93-94 hub or some sort of spacer ring made up. The only reason for the CPS is to detect missfire. You don't need it to run.
Old Dec 20, 2005 | 09:49 AM
red96z's Avatar
im going to customize the ring to make it fit! has anyone else done this?
Old Dec 20, 2005 | 09:56 AM
LT4383's Avatar
Save yourself the headaches and do without the ring. Use a '95 cover and you won't have to worry about plugging the hole for the CRK sensor.
Old Dec 20, 2005 | 11:35 AM
sssalah's Avatar
I've tried, ended up with lots of metal shaving in my oil. Like everybody has suggested, save yourself and get rid of it, I finaly did and I'm still running OBDII.
Old Dec 20, 2005 | 11:49 AM
red96z's Avatar
so if i go with another cover i also need a new hub? my mechanic said it can be done and he can do it ,hes the best around builds promods! dwayne watkins is his name. with all the new parts its going to be a problem buying new cover and hub!
Old Dec 20, 2005 | 11:55 AM
OBE1 95Z28's Avatar
If you go with a 95 style cover, you still need a new hub as the hub has to be longer to butt up to the timing gear.
Old Dec 20, 2005 | 12:45 PM
red96z's Avatar
but i can still use the 96 cover and just buy new hub?
Old Dec 20, 2005 | 12:50 PM
red96z's Avatar
or use the 96 hub with spacer or a 94 95 style hub with no spacer!
Old Dec 20, 2005 | 01:07 PM
OBE1 95Z28's Avatar
If you use the 96 hub with a spacer and the 95 style cover, the spacer will need to be designed to not interfere with the cover. You'll also need to look at where the crank seal mates with the hub/spacer to make sure that it seals properly.
Old Dec 20, 2005 | 01:53 PM
Birdman7389's Avatar
Wow, enough confusion.
Use your existing cover, ditch the reluctor and program the CPS out, and get a 94-95 hub. You can leave the actual CPS in place, or remove it and use a freeze plug in the hole.
Old Dec 20, 2005 | 04:08 PM
1racerdude's Avatar
I just answered all these questions in an earlier post he had.
Obviously he doesn't want to get rid of the wheel.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
mmf_1013
Sep 12, 2015 08:56 PM
blaze309
Sep 8, 2015 05:27 PM
realistyc
Jul 28, 2015 07:32 PM
