Do comp 987's need spring locators
Old Apr 10, 2009 | 05:37 PM
mightymouse383's Avatar
Quick question, do comp 987's need spring locators? Need to know so i can order them, also should i use a +.050 lock on a 740-16 steel retainer and will the lock help me acheive the suggested spring height of 1.800.......thanks in advance for any help.
Nick
Old Apr 10, 2009 | 06:15 PM
raroz28's Avatar
Nick
Not sure, but if you plan on ordering those springs with ID locator's, I have a set of 978's that require ID locators and are good to .600 lift (according to my machinist). I went with beehives instead, but I'm selling those springs for $60 shipped. I paid like 130 for them. Dual coil style.
Old Apr 10, 2009 | 09:16 PM
Cook Performance's Avatar
I can sell you a complete 987 spring kit with locators, retainers, seals and the proper valve locks. Free shipping on all items! Email me at jakecook@cpengines.com. www.cpengines.com
Old Apr 10, 2009 | 09:50 PM
rskrause's Avatar
Moderator
All springs on Al heads need cups or locaters.
Old Apr 11, 2009 | 04:46 AM
Question
Well i already have the springs, retainers and just need the locks, locators and the seals. I was looking at comps master catalog and it showed that the locators for 987's were N/A and only listed the part # for shims, also will the standard umbrella valve seal work? I do not want to have to machine the guides for the teflon seals. Heads are atill on the car and am getting ready to install a cc306 with comp pro mags (1.6).
Old Apr 11, 2009 | 06:56 AM
rskrause's Avatar
Moderator
Hardened shims will protect the heads though they will get a little beat up. Standard seals will work ok IF they will fit inside the springs. You don't need Comps locater, any ones that is the right size will work.
Old Apr 11, 2009 | 10:20 AM
I tried calling comps tech support line and can't get through, well i guess i will keep searching for the correct locators and locks.
Old Apr 11, 2009 | 10:57 AM
raroz28's Avatar
When I had 987's I used comp 740 locks.
The locators you need are 4771-16
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
