Do Comp 977 valve springs require seat work?
Old May 24, 2007 | 08:26 PM
2QUIK6's Avatar
I think I have Comp 977 springs with a 1.46" OD and if I ever went to a smaller / lighter spring with a smaller OD if I get a cam with less lift, what is required? I'm thinking the 977's did require seat work but they were on the heads when I got them.
Do they make shims/cups for smaller OD springs than what the spring seat was cut for?
For say like Comp 26918 springs which have a 1.29" OD on bottom to replace the 977s
Old May 25, 2007 | 04:09 AM
rskrause's Avatar
Moderator
Yes, even if the spring pocket has been cut you can use a smaller OD spring with the correct seat/locator.
Rich
Old May 25, 2007 | 09:42 AM
BUBBA's Avatar
Your current seat were probably not machined. I believe the stock seat will accommodate 1.46s. So why are you going with smaller OD springs anyway?
Old May 25, 2007 | 10:49 AM
2QUIK6's Avatar
May be going with a cam with smaller lift so I may switch to the lighter 26918 springs to give the rest of the valve train a break too.
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
