Camshaft Innovations - has anyone used them?
I'm been reconsidering and am now thinking of going with a custom grind instead of the GM847. I've been looking around alot and originally I wanted to go with Joe Overton, but unfortunatly it appears he isn't doing custom cams anymore. So I checked out camshaftinnovations.com.
I emailed jay and he seemed pretty knowledgable, and I've read alot of good stuff, but no actual reviews of his cams in an LT1.. Does anyone here actually use his camshafts or have direct experience with him?
The good part about using a shelf cam is someone somewhere has one so you can get all the parts easily, cheap and you can get it tuned easily or find a good PCM file on here. But once you go custom grind, you need more expensive parts, more expensive cam but more HP. I have used Cam Motion before and was satisfied but now have a cam form Brett Bauer thats not quite running yet but won't be long. .
3 to 4 more MPH is not going to happen if the 847 is in the ballpark with what your combination needs, with all other things working fine.
i just bought a cam from jay. He truely knows his stuff, you cant go wrong. I had him do a smog legal for me with some le2 heads he says high 11s on motor should be very easly attainable.(with the right suporting mods of course)
Well at this stage in the game I'd like to get something that's going to trap at least low 120s. I've seen traps of 120 with the 847 so I'm thinking this is attainable.. hell I'll sacrifice a bit of streetability to get to my goal..
Thanks for the comments on Jay, I'm pretty sure I'll be going with him. I have yet to find a negative review of his product.
Pretty pathetic, a guy I know of with a full body, full interior 95Z with an auto and small cam runs 8.20's all day and super low 7's on an 80hit.
