DMH Cut-Out
You can only get it from DMH directly. They are a paying advertiser on this site. So go there and click on the link. Mine is installed right before the axle. Right next to where it is there is a little rubber peice that is under the carpet right behind the passenger seat. I ran the wire from under the carpet there to the side panel and ran it underneath that to the front. Then up under the dash into the center console. It comes with plenty of wire.
Im about as noobish as can be and it took me about a half hour to run the wire from under the car to the dash (put switch under cig lighter)
edit: on the other hand, im not sure how to wire it from there
Kain
Feb 11, 2003 01:12 AM
