DMH Cut-Out
Old Jan 27, 2004 | 06:02 PM
My 97 Z28's Avatar
DMH Cut-Out
Where's the cheapest place to get a DMH Cut-out? Also, where did you guys put your switch for the cut-out? How did you wire it?
Old Jan 27, 2004 | 06:35 PM
drewstealth's Avatar
You can only get it from DMH directly. They are a paying advertiser on this site. So go there and click on the link. Mine is installed right before the axle. Right next to where it is there is a little rubber peice that is under the carpet right behind the passenger seat. I ran the wire from under the carpet there to the side panel and ran it underneath that to the front. Then up under the dash into the center console. It comes with plenty of wire.
Old Jan 27, 2004 | 06:39 PM
My 97 Z28's Avatar
Any pictures? How long did it take you to wire it? Was it hard?
Old Jan 27, 2004 | 06:52 PM
JoeliusZ28's Avatar
Im about as noobish as can be and it took me about a half hour to run the wire from under the car to the dash (put switch under cig lighter)
edit: on the other hand, im not sure how to wire it from there
Old Jan 27, 2004 | 07:25 PM
It took me about 1 hr to do the wireing but i was doing it in the dark and that always seems to slow things down.
Koby
Jun 28, 2015 04:46 PM
meangreen94z
Apr 18, 2003 05:58 PM
Kain
Feb 11, 2003 01:12 AM
I CORNER
Jan 29, 2003 11:53 PM
BergerSS435
3rd Gen / L98 Engine Tech
Jun 10, 2002 10:37 AM
