dmh and borla dmh guys, quick question
Old Jun 9, 2005 | 08:18 PM
Makaveli's Avatar
when you installed the cutout, did you install it in the open position to make sure that it didnt get stuck or something if it was a little out of place? i installed it in the closed position, (on the borla catback) and it gets stuck relatively quick, i guess i never considered it could be at a point where it would bind with the pipe.
Old Jun 9, 2005 | 09:07 PM
ulakovic22's Avatar
Re: dmh and borla dmh guys, quick question
I installed mine closed and it did bind on the pipe when I first tried it. Just loosen up the bolts and rotate it a little while someone opens and closes it. That's why those holes are elongated. Also you can take a flash light and look in the tail pipe to see if it opens all the way or not. I could barely see up the pipe, but it was better than doing it blind.
cmdeshon
Dec 27, 2014 10:06 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Red97LT1
Aug 7, 2002 05:45 PM
