dmh and borla dmh guys, quick question
when you installed the cutout, did you install it in the open position to make sure that it didnt get stuck or something if it was a little out of place? i installed it in the closed position, (on the borla catback) and it gets stuck relatively quick, i guess i never considered it could be at a point where it would bind with the pipe.
Re: dmh and borla dmh guys, quick question
I installed mine closed and it did bind on the pipe when I first tried it. Just loosen up the bolts and rotate it a little while someone opens and closes it. That's why those holes are elongated. Also you can take a flash light and look in the tail pipe to see if it opens all the way or not. I could barely see up the pipe, but it was better than doing it blind.
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
