dist. cap change please reply!!!
Old Feb 16, 2003 | 06:51 PM
billy-94z28's Avatar
Guys, can the dist. cap and rotor cap be changed on a 94 z28 without pulling the water pump. today, I cranked up may car and it idled rough and rpm would go up and down when i turned on the heater. it even died one time. drove down the road and smoothed up some, seemed more i drove it smother it ran. temp was very warm (half way on gauge) as i took off it farted back through the mufflers a couple of times and would miss then eventually level off. only mods is a k and n fresh air system. 65,000 miles original ignition system and plugs changed on 30,000 miles please reply.
Old Feb 16, 2003 | 06:55 PM
RamAir95TA's Avatar
Either way, your waterpump needs to come off. I'd recommend changing the entire opti, because only a few people have had a whole lot of luck just by changing the cap and rotor.
Old Feb 16, 2003 | 07:37 PM
Compstall's Avatar
What he said. There are a few bolts that sit behind the water pump you can't get to without removing it.
- Brent
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
carcrazyQT
Sep 17, 2002 07:54 AM
carcrazyQT
Sep 3, 2002 02:51 PM
carcrazyQT
Aug 8, 2002 01:54 PM
carcrazyQT
Aug 6, 2002 07:19 AM
