Dissapointing dyno results
Old Feb 11, 2003 | 07:02 PM
  #16
scott95ta's Avatar
ttt for some new looks
Old Feb 11, 2003 | 07:50 PM
  #17
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Dynoing the car in a lower gear will always give you a lower readings due to more INERTIAL loss to the drivetrain.
Old Feb 12, 2003 | 08:32 PM
  #18
scott95ta's Avatar
I had a friend look at the DataMaster file for me. Two things, my O2 readings are not going up above 700mv at WOT and my car is not in closed loop. I dynoed in Open Loop. I looked at the log and from start up to the end of the dyno runs were less than a minute. I remember reading somewhere that it takes "x" amount of time from start-up for the car to into Closed loop, no matter what the temp is.
So now I have a few things to do. Replace the O2's, fix the y-pipe from knocking causing the Knock Retard and re-test in 3rd gear and in Closed loop.
Thanks for all the advice. I will keep you guys posted. It will probably be at least a couple of weeks before I can go back.
Old Feb 12, 2003 | 10:10 PM
  #19
INTMD8's Avatar
The car will always go into open loop at WOT.
Old Feb 12, 2003 | 10:20 PM
  #20
scott95ta's Avatar
But even on acceleration and at idle it was not in Closed Loop.
Anybody know how long the car has to be running, assuming it is at the proper temp, to go into closed loop?
Old Feb 12, 2003 | 10:36 PM
  #21
Dr.Mudge's Avatar
2-3 minutes about, unless its freezing where you live. With the 180º you should have no problems though.
fift5
11
Oct 1, 2015 10:31 AM
HAWG
Sep 25, 2015 11:41 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
