Disconnecting T56
Disconnecting T56
I removed my engine and trans but can not get them separated completely. Do i need to remove the shifter from the transmission for them to separate? I know this may seem like a dumb question but i've never removed a T56 before nor have i ever removed a engine from the bottom until tonight.
Re: Disconnecting T56
So i'll be able to do this by hand and straight back towards the rear of the trans? It's sitting on the gargage floor right now. The adapter block is what the slave was bolted to correct?
Yeah, it's pretty simple. Take off the two 13mm nuts, pull the slave out, remove the block. The fork pulls straight out of the hole, not back. It's literally a fork, wrapped around the T/O bearing.
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
