Disconnecting T56
Old Mar 4, 2013 | 08:50 PM
dalynchmob's Avatar
Disconnecting T56
I removed my engine and trans but can not get them separated completely. Do i need to remove the shifter from the transmission for them to separate? I know this may seem like a dumb question but i've never removed a T56 before nor have i ever removed a engine from the bottom until tonight.
Old Mar 4, 2013 | 09:00 PM
Re: Disconnecting T56
The most common error is not disengaging the clutch fork.
Old Mar 4, 2013 | 09:05 PM
dalynchmob's Avatar
How would i do that? Only transmission work i've done is an SRT4.
Old Mar 4, 2013 | 09:12 PM
kevhogaz's Avatar
Remove the slave cylinder, and adapter block. Pull the clutch fork straight back. You'll know when it's disconnected, as it'll be obviously loose.
Old Mar 4, 2013 | 09:15 PM
dalynchmob's Avatar
So i'll be able to do this by hand and straight back towards the rear of the trans? It's sitting on the gargage floor right now. The adapter block is what the slave was bolted to correct?
Old Mar 4, 2013 | 09:22 PM
kevhogaz's Avatar
Yeah, it's pretty simple. Take off the two 13mm nuts, pull the slave out, remove the block. The fork pulls straight out of the hole, not back. It's literally a fork, wrapped around the T/O bearing.
Old Mar 4, 2013 | 09:23 PM
97WS6SCharged's Avatar
It'll actually pull down like you're trying to pull it out of the transmission. And yes, you can do this by hand.
Old Mar 4, 2013 | 09:30 PM
dalynchmob's Avatar
OK thanks. Will i have to re seat the bellhousing to the engine to make this work? I removed all the bellhousing bolts and it slide apart about 2 inches.
Old Mar 4, 2013 | 09:34 PM
kevhogaz's Avatar
Just push it back in, you shouldn't have to bolt it back up. The fork isn't really in there very tight. It's just held in by the T/O bearing, and a spring clip.
Old Mar 4, 2013 | 09:38 PM
dalynchmob's Avatar
Thank you very much guys i would have ended up breaking something i'm sure.
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Bxlt1
Sep 29, 2015 03:18 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
