dipstick tube broke in half
I was changing the oil the other day and the dipstick tube literally broke in half. what is the best way to replace this? do i need to drop the oil pan? i also have new poly motor mounts would this be a good time to change those out as well?
Re: dipstick tube broke in half
I removed my tube when installing headers. It slides in, mine was a bear to remove the first time. But yeah, I would do this with the motor mounts while your under there.
There's one screw holding a flange on the tube to the block. Might take a little work to pull it out, but since it's broken already you can put some vise grips or something on it. A screwdriver might help to pry it out of the block too.
Before you put the new one in, put it in the freezer overnight so it shrinks a little bit.
colts0455
Jul 28, 2015 11:28 PM
