Dip stick tube gromet?
Old Sep 17, 2003 | 01:59 AM
CamaroRob97's Avatar
while in the preocess of putting things back together after installing my new valve springs i noticed my dip stick tube was loose, real loose, infact i could pull the tube completley out! Im assuming that theres a gromet i need to replace so it'll stay stationary, any one got a GM PN for me or any other tips to take car of this would be aprreciated!
Old Sep 17, 2003 | 03:09 AM
carlos64030's Avatar
You'll have to order another dipstick tube from G.M., for the bracket that holds the tube to the block is an integral part of the tube.
Old Sep 17, 2003 | 04:28 AM
revtime's Avatar
There should be a bracket on the dipstick tube so you can bolt it to the block.
If the bracket is still on the tube then all you need is a bolt to fasten it back on, if the bracket broke off then you will need a new tube.
Old Sep 17, 2003 | 07:06 AM
ibanez6rg's Avatar
I think he's talking about the actual gromet on the block where the dipstick does in.
Old Sep 17, 2003 | 08:01 AM
There's not one, is there? AFAIK, it's just an interference fit and no grommet (at least that's the way it's always been in the past).
football4life
Oct 4, 2015 07:48 AM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
DarksideII
Parts Wanted
Sep 23, 2015 11:14 PM
dolfan324
Jul 17, 2015 10:34 PM
