Dimmer switch/guage problem
Old Nov 3, 2003 | 08:56 AM
ZBLKHELLRZR's Avatar
Question Dimmer switch/guage problem
I'm running autometer guages and they all work properly. But my problem is my dimmer switch allows the guages to dim up or down but my actual dash does not. I've double checked everything and I still have the same end result. Anyone have any ideas? I'm getting pissed because it looks mighty gay at night w/ the guages workin but not the dash. Thanks.
Old Nov 12, 2003 | 09:14 AM
Anyone got any ideas on this? What's weird is the dimmer switch will work for the external guages ie, tranny temp, boost etc as long as the wiring for the guages are hooked to the fuse but still the dash overlay won't dim. So if I run it unhooked to the fuse for the interior all is good but the dash still doesn't work. Help!!!
Old Nov 12, 2003 | 09:18 AM
ishz28's Avatar
Sounds like a broken or loose wire. All I can say is run your wires. Start at the back of your dimmer switch and go from there, shouldn't be that much wire.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
