Dilemma
Old May 20, 2005 | 09:32 AM
panman79's Avatar
Dilemma
My nonvented opti went out. I would like to convert to a vented opti. My friend tells me I have to pull the cam and grind the dowel pin down. I have about 400 to blow if I want. My friend tells me the lt4 hotcam kit is 500 w/ everything you need for the install. I can't afford 500.
Is there a cheaper mild cam I could shove back into the motor on a stock valvetrain? Car has 140k miles nad runs awesome. Or should I just stick with a non vented opti for now?
What would yall do?
Old May 20, 2005 | 10:07 AM
Compstall's Avatar
Re: Dilemma
The hotcam is the cheapest cam on the market.
Old May 20, 2005 | 10:24 AM
Re: Dilemma
Vented Opti conversion page:
http://para.noid.org/~muttvette/opti.html
Old May 20, 2005 | 12:55 PM
MeanGreen97Z's Avatar
Re: Dilemma
You can replace the cam but at 140k miles you are definately in need of some valve springs, shims, locks, and retainers. You can get a lightly used lt4 cam out of the for sale section or a similar one for 150 or less. Then get yourself a good valve spring set up. Check your pushrods and rocker arms for wear. Also replace the valve seals while you are in there. Seals are dirt cheap. It's possible that the roller lifters are worn so be sure to check them also. You can get a cam swap for ~300$ but that doesn't take worn parts into consideration. I'd save that 400$ and double it over time and replace all those parts at the same time.
Old May 21, 2005 | 07:32 AM
panman79's Avatar
Re: Dilemma
I just ordered a non vented opti from Dal. I'll do the cam swap next time. Thanks for the help and advice yall.
3.8LCamaro98
Jan 31, 2005 07:43 AM
UTbird06
Oct 13, 2003 07:50 AM
