difficult to change opti??
Old Jul 14, 2007 | 03:08 PM
Camaro1996's Avatar
hey guys what up? i was wondering how difficult it is to change the opti? does it take awhile? what about plug wires, are those tough?
thanks!
Old Jul 14, 2007 | 03:33 PM
rexcellent's Avatar
Its not too bad. If I recall correctly you just have to take off the water pump and then you can get to it. You might have to take off the throttle body, not sure if you do or not. It has been a few years since i changed mine.
Old Jul 14, 2007 | 05:06 PM
er-z's Avatar
its not that bad, but plan on doing this on a weekend . here look at this http://www.houston-f-body.org/forums....php?topic=9.0
Old Jul 14, 2007 | 05:31 PM
mrmint69's Avatar
I had a small drip from the pump and figured i would replace the opti at the same time. It took about 3 hours to do and i did plug wires also. I also had 3 hours running to buy parts that were frozen on or just needed replaced since it was apart. My supercharger made it a little more compliated as well.
Old Jul 15, 2007 | 06:47 AM
Laymaster's Avatar
If you are well-versed or moderately versed with working on your car yourself it shouldn't be too bad. A little cautious approach the first time and it should take you about 5-6 hours (with breaks here and there). None of the bolts are real bitches like when you remove the bell-housing on a transmission.
Once you've done it once, it becomes a 2-3 hour job between draining and refilling the radiator (don't want that stuff to drip on you). It's not that hard. Just make sure you have a harmonic balancer puller.
Old Jul 15, 2007 | 09:16 AM
my94blackz's Avatar
1 hour and 15 mins. Timed myself one time.
Old Jul 15, 2007 | 12:52 PM
Laymaster's Avatar
that is quite plausible as well. How many times have you done it?
Old Jul 15, 2007 | 12:57 PM
94Camaro_Z_28's Avatar
It's not all that hard. On the 96, just make sure you get the Opti indexed to the cam right. I done it on my 94 and my 95.....got it down to a science I've done it so many times. i think it took me about 4 hours the first time I did it, now it takes right around an hour.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Sergio
Jan 27, 2016 04:27 PM
grabbem88
Mar 18, 2015 01:25 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
grgguy
17
Feb 23, 2015 07:57 PM
