different LT1 heads from GM???
I guess I should be more specific. I was told that the 94 25th anniversary trans am heads have a lower chamber volume. 54.4 cc's versus the standard 58 cc's of a regular lt1. Did any lt1's come with this chamber volume? I know the lt4's did.
Well I am thinking of buying them and we will see. Maybe I misunderstood him but he claims they are 54.4 cc's and I will call him on it if it is B.S. He lives close to me so I am not very worried about it. But if they are higher compression I will gladly accept them. Any little advantage helps. Tom
Tom,
Aluminum LT1 heads.
10205245, 10128374, 10207643, 10207640, 12551561.
As far as I know the only head that is different is the 561 (lighter casting). I have them on my latest LT1 and have had very little gain with them so far.
I mill all of my heads to about 52.5 cc's (NHRA minimum is 51.9).
The cast iron LT1 head is 14088526 (62.0 minimum).
The LT4 head is 12555690 (54.4).
Best Regards,
Daren
Aluminum LT1 heads.
Best Regards,
Daren
Ok I am also looking at a set of steel or cast iron lt1 heads. The only numbers they have shown are 25320. Is this an lt1 head?
So if these are high cc heads I can just have them milled to like 53 or 52 cc's. Will I run into piston to valve clearance issues then?
Thanks for all the help guys.
here is a link to the low cc heads:
http://cgi.ebay.com/ebaymotors/ws/eB...411459826&rd=1
Originally posted by GUMP
Tom,
Aluminum LT1 heads.
Tom,
Aluminum LT1 heads.
oldschool
Feb 9, 2016 09:21 PM
