A different kind of oil pressure problem...
Old Jan 19, 2008 | 12:00 PM
  #16
klrz28's Avatar
Lots more oil pressure if you get rid of it. Its not really an oil cooler its an oil temp stabilizer for emissions. Well worth it it only takes about 30 mins to remove. cap the line coming out of the radiator and cap the line coming out of the water pump or couple them together. Capping them off is the way to go In my opinion.
Old Jan 20, 2008 | 12:22 PM
  #17
Whitey13's Avatar
So I replaced the sending unit (pita) after running seafoam in the crankcase (with the old oil) for 100 miles then putting in 5w-30 castrol gtx conventional. Oil pressure at cold startup is 60 psi and warm idle is 25 psi. WOT is 60+ psi. Not too shabby for a 180,000 mile LT1
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
