A different kind of oil pressure problem...
Old Jan 18, 2008 | 04:16 PM
Whitey13's Avatar
After lots of searching, I couldn't find the answer so here goes...
Oil pressure on cold start up is 35 psi give or take a few pounds.
Once it's warmed up at idle, it's between 10 and 20 psi.
Crusing, it's about 20 to 23 psi.
WOT, it never goes above 30 psi. I mean when it's bouncing off the rev limiter, it doesn't change. Power is there and everything sounds just fine. Possible oil pressure sending unit problem? Or much worse?
Old Jan 18, 2008 | 05:12 PM
Sending unit problem possible. Or your bearings or pump are not so healthy.
Old Jan 18, 2008 | 05:29 PM
Whitey13's Avatar
Thanks shoebox. Is there any kind of damage being done running at high rpm's without the oil pressure keeping up?
Old Jan 18, 2008 | 07:05 PM
Low oil pressure and high RPM is a recipe for bearing damage.
Old Jan 18, 2008 | 07:16 PM
'94 Bad A Z28's Avatar
Umm... P.S. your A4 car should NEVER bounce off the rev limiter.
Old Jan 18, 2008 | 08:35 PM
Whitey13's Avatar
And why is that?
Old Jan 18, 2008 | 08:41 PM
klrz28's Avatar
remove oil cooler, 9 times out 10 its plugged
Old Jan 18, 2008 | 09:13 PM
Did I miss where he says he has one?
Old Jan 18, 2008 | 09:27 PM
Originally Posted by Whitey13
And why is that?
Because if it does not shift when it is supposed to, unless you hold the gears manually and let it bounce of the limiter for some reason, it is on it's way to needing a rebuild or already needing one.
Old Jan 18, 2008 | 09:50 PM
Whitey13's Avatar
Oh, I thought you meant it was bad for it or something... But no, it shifts when it's supposed to, I just meant when I go through the gears and bring it up to the top of each gear.
Old Jan 18, 2008 | 10:38 PM
Whitey13's Avatar
Are oil coolers a factory option? How do I know if I have one?
Old Jan 18, 2008 | 11:05 PM
Your car would have RPO KC4 on the sticker in the glovebox and you would see hoses going from the radiator and the water pump toward a sandwiched block between the oil filter and the engine block.
Old Jan 18, 2008 | 11:25 PM
Whitey13's Avatar
That's some good info, I appreciate it. I just got back from a cruise and I noticed at a stop sign my oil pressure needle was bouncing around. It was steady at 15 psi then it instantly went to 20 then back to 15 and kept doing that then for a couple seconds before it went back to 15. The car was running and idling just fine though. It's starting to sound like the sending unit is going...
Old Jan 19, 2008 | 08:53 AM
Guest47904's Avatar
Guest
If coolant flows through the oil cooler, how can it cause an oil pressure problem?
Just a little confusion????? Clearly from Shoe's diagram, the coolant flows to the oil cooler NOT oil to the radiator. So if that's the case, how could a plugged oil cooler create problems with oil pressure???? Would it be just from temperature build up? I wouldn't think so.
Maybe one easy test would be to put a thicker oil in and see what the pressure does. According to accepted standards, for every 1000 rpms there should be an increase of 10 PSI.
Old Jan 19, 2008 | 09:59 AM
No, the cooler gets clogged from particles within the oil only part of the cooler.
