differences in 94 and 97?
Old Jun 15, 2005 | 10:54 PM
Zaddiction27's Avatar
what is the difference in 94 and 97 lt1's? Is it just the timing and vaccum hoses? I have a 94z but i also have a 97lt1 from a z and wish to have it rebuilt to a 355 forged setup. Is it possible to have it done or are the blocks themselves different? I will have the z taken off the road if need be but I have the other engine so I figure I could ask you all first.
Thanks in advance,
chris
Old Jun 16, 2005 | 12:18 AM
OBE1 95Z28's Avatar
Re: differences in 94 and 97?
Look here:
http://www.f-body.org/faq/4/4_1.htm
Old Jun 16, 2005 | 12:43 AM
mr_will's Avatar
opti,timing cover, obd1 and obd2 are the biggest differences i believe
Old Jun 16, 2005 | 04:01 PM
I guess what I am trying to get at is can I use the 97 block in my 94? Are the blocks any different
Old Jun 16, 2005 | 04:09 PM
Silvershark's Avatar
You can use the actual block with no problems.
Old Jun 16, 2005 | 04:30 PM
thank you, first time I have gotten a simple answer and you deserve a cookie.
So all I need to do now is get it torn down and brought to a machine shop for phase 1 then forge all internals use cam(larger), timing, hoses, harness, pcm, (ported stock)heads from 94 and bam engine done. You have made my day
Old Jun 17, 2005 | 02:55 AM
No problem. Yup, sounds like what you are doing is fine.
WobblySausage
Oct 7, 2015 02:44 PM
NewsBot
Sep 30, 2015 04:20 PM
SergheiS
Sep 29, 2015 08:56 PM
Bxlt1
Sep 29, 2015 03:18 PM
