Difference in single pattern and dual pattern cams?
Old Apr 22, 2003 | 11:53 PM
LT1ponykilla's Avatar
Just as the title says. I know most of the newer cars are running the dual pattern cams. I have heard that a single pattern cam will give you more power than a dual as far as torque is concerned. Will a single pattern cam work in a fuel injected car?
Old Apr 23, 2003 | 08:09 AM
grygst76's Avatar
single pattern cams work great on a car with excellent exhaust flow which chevies suffer from not having. You can use a single pattern if you have a low restriction exhaust w/o ported heads or with ported. they can make more power if you have the above mods if not go with dual which means higher lift on the exhaust.
DirtyDaveW
Mar 15, 2015 07:01 PM
Jan 23, 2015 01:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
