Difference between camaro and impala lt1
Old Feb 26, 2022 | 06:11 PM
  #16
msjohnson2359's Avatar
Re: Difference between camaro and impala lt1
Originally Posted by dabez1
I droped an impala engine into my Trans am after my engine died. Major differences are the Heads which are cast iron which are suppouse to flow a bit better than aluminum but weigh around 35-40lbs more. The cam is milder than the camaro cam, but produces more torque are lower rmps the the camaro cam (To get the heavier b-body cars moving), and its only rated 15hp less than camaro, but has far more restrictive exhaust, and intake. Water pump is also different. Appart from that everything preaty much is the same.
I have my engine running with stock programing from my t/a computer, and have beaten more than a few camaros, so dont think the impy engine is any weaker. Im sure tunning for the different cam gain even more hp.
Did you have to flash the PCM because of the different parts!
Old Feb 26, 2022 | 09:43 PM
  #17
“dabez1” hasn’t signed in to this site in 12 years. The second paragraph in his post you quoted indicates the B-Body engine runs on the F-Body tune. But then he indicates it will run better with the F-Body tune. Look carefully at post #8. There's relevant info there.
Dec 1, 2014 08:08 AM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
Double aught
Nov 23, 2014 03:15 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
