Difference between 93 6 spd throttle body and 94 Impala throttle body
Old Mar 2, 2003 | 11:03 PM
Momar's Avatar
Here's the deal. I have a LT1 out of a 94 impala that I will eventually put into my 85 trans am. I was wondering if it would be possible use a throttle body from a 93 or if the sensors and such were different. I have a 700R4 so I would need the spot to connect the tv cable. I was also wondering if they made different throttle bodies for the auto's and manual's in 93 or if they used the same one. If they used the same one and the different years are compatable, my cousin has a 93 LT1 and T56 that he will be putting in. I havent been able to check and see if his has the spot for a tv cable even though it came with a 6 speed or not. I have my doubts on that but I have also found someone who might be willing to trade me a 93 auto throttle body if they are comatable and I pay shipping. Does anyone know what will or wont work?
Ben
Old Mar 3, 2003 | 07:33 AM
Momar's Avatar
ttt
Old Mar 3, 2003 | 10:27 AM
DirtyDan's Avatar
I've got a stock 93 auto throttle body. Needs the top and bottom plate + sensors (probaly on the Impala one) Shoot me an E-mail and we'll talk.
Dan
Old Mar 3, 2003 | 10:51 AM
Gripenfelter's Avatar
On the 93s you have 3 cables that hook up.
Accelerator cable.
TV cable (autos).
Cruise Control.
94s+ only have an accelerator cable.
Old Mar 3, 2003 | 01:16 PM
Momar's Avatar
Accelerator cable.
TV cable (autos).
Cruise Control.
I know that the 93's had the tv cable, although my friend has a throttle body off of a 94+ vette(not sure exact year) and it has a spot for the throttle cable and another spot which I assumed was cruise control. Even if it is computer controlled the computer has to have a way to pull the throttle for cruise control.
Ok, back to the question. What I was wondering is if the electronics between the 2 are compatable. If so I plan on using one from a 93 so that I can use my 700R4.
My other question was if the manual and auto throttle bodies were different in 93 or if they both had the spot for the tv cable even though the manual didnt use it. I asked on thirdgen.org and a guy that has swapped a 93 LT1 into his thirdgen RS said that the 6 speeds did have the spot for it, it just wasnt used. If this is the case my cousin has a 93 w/ six speed and I could probably swap throttle bodies with him.
Is there any difference in the 93 and the 94+ throttle bodies other than the fact that they have different hook ups for the cables? Are they the same cfm and do they use the same sensor?
Ben
Old Mar 3, 2003 | 05:23 PM
Momar's Avatar
ttt
Old Mar 3, 2003 | 05:59 PM
They are the same if you are referring to the TPS and IAC, etc. No other electronics on there.
6 speeds don't have a spot for the cable because its actually a bracket that bolts to the TB. Which actually you could make out of a sheet of metal. Just drill the holes and cut a square hole for the TV cable connector.
Ben
No other differences other than what you have already stated.
Old Mar 3, 2003 | 06:19 PM
Momar's Avatar
So, how does this bracket attatch? Does someone have a picture. Does can this piece be ordered and put on a 93 6 speed throttle body or even on a 94+. T talked to someone on thirdgen.org that said that the 93 manual tranny cars had the spot for the tv too. I dont know if he had an auto or manual, but he had a 93 LT1 in his 91 RS.
Ben
Old Mar 3, 2003 | 09:39 PM
I forgot to mention that there is a little button on the shaft of the throttlebody that the TV cable clips to.
You can fashion your own type of connector and weld it on I guess.
I'm sure you could get the bracket from a dealership or a wrecker.
If you can't find a pic by the weekend let me know and I'll take some pics for you.
I'll borrow my fiance's digi cam on friday.
DesiZ28@hotmail.com
Old Mar 4, 2003 | 12:10 AM
Momar's Avatar
So then, do you know if you could attach this piece to a throttle body from a 93 w 6 speed, or if I just need to find one from an auto?
Ben
Old Mar 4, 2003 | 07:18 AM
Momar's Avatar
ttt
HectorM52
Jul 30, 2017 11:46 AM
CARiD
Feb 9, 2015 09:35 AM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
formula79
Jul 12, 2002 01:58 AM
