Difference between 383 and 355
Old Nov 28, 2011 | 08:38 PM
sszcam's Avatar
Recently found out the engine in my 95z is bored 30 over.don't think it's a383 because it's not that strong.whats the difference other than the crank of course
Old Nov 28, 2011 | 08:51 PM
Kevin Blown 95 TA's Avatar
Re: Difference between 383 and 355
28 cu in and more low end grunt. There's endless information on it available on the web and even on this site.
Old Nov 28, 2011 | 09:16 PM
sszcam's Avatar
Are the rods different...length wise...
Old Nov 28, 2011 | 09:38 PM
cnorton's Avatar
Not necessarily. Some builders choose to stay with the 5.7" rod and others prefer 6.0".
Old Nov 29, 2011 | 05:42 AM
bw_hunter's Avatar
Sure 28 CID more but usually much higher compression which has a profound effect...
Old Nov 29, 2011 | 12:04 PM
You can build it to have any compression you want.
Old Nov 29, 2011 | 12:12 PM
96capricemgr's Avatar
People have built 383s that made less power than stock engines, by blindly adding displacement without any clue what was good or what made power. You add displacement but do it with cheap parts and cheap machining and you can make less than stock power.
There was a kid around for awhile that had a 383 Impala that made 220rwhp with headers which is what the stock b-body engine made through manifolds on stock 87 octane tuning.
Then at the other end of the spectrum there are those who top 400rwhp or even 420+rwhp without changing the rotating assembly atall still a 350 naturally aspirated.
Old Nov 29, 2011 | 12:22 PM
bw_hunter's Avatar
Of course you can, that's what the "usually" meant.
Old Nov 30, 2011 | 10:41 AM
dennis5374's Avatar
I've ridden in well built 383's and 355's. Imho the 383 had much more torque throughout the low and midrange. I think they're about even on top end but I have seen some pretty sick 383's that revved too 8500-9k with ease. Impossible to tell the difference without disassembling the motor . Obviously there is no replacement for displacement but like dwayne said there are stock shortblocks making over 400rwhp
Old Nov 30, 2011 | 12:24 PM
Compression is adjusted when you build it, so why would it "usually" have more compression unless you wanted it to? You could say that people "usually" build their 355s with more compression, or their Honda 4 bangers. And it depends on the cam as well as the pistons, heads, gaskets, etc. what compression you end up with - and don't forget how dynamic compression figures into it - it's not just static. You don't use all the same parts and just get more static compression, and therefore more power, from the longter stroke. Is that what you're trying to say?
Old Nov 30, 2011 | 12:38 PM
bw_hunter's Avatar
I was just suggesting that people go to higher static compression when building 383's. I understand static v dynamic but was making a general statement, not a specific build....
Old Nov 30, 2011 | 10:51 PM
Plenty of rebuilt LT1s 355 or 383 end up with stock or lower compression because clueless people use clueless machineshops. Have actually seen NA LT1 with a mild "performance" rebuild by a reputable shop with compression somewhere down around 9.5:1
Old Dec 1, 2011 | 06:23 PM
TeeTopZ's Avatar
Surprised no one mentioned it, but the additional cubes come from the the increased stroke from the new crank. 3.75 rather than 3.48. This makes the motor very torquey in the lower rpm ranges, making for a great street motor
Old Dec 1, 2011 | 06:53 PM
Over stated. A properly done 355 can easily have more lowend than you can use on the street.
MadMav
Jun 8, 2015 11:38 PM
drptop70ss
Mar 26, 2015 01:50 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
InfernalVortex
Jan 17, 2015 09:35 AM
