Difference in AFR 220's and 227's ??
Old Jul 18, 2004 | 07:21 PM
Hyperspeed97z28's Avatar
What is the difference in the AFR heads the 220's and 227's ??
Are these good heads unported ???
Old Jul 18, 2004 | 08:36 PM
TQdrivenws6's Avatar
Re: Difference in AFR 220's and 227's ??
If you are going to spend the $$$ on the required valvetrain and want to run them non ported, it would almost seem as if you didn't realize what you were getting into. (no flame intended)
They are great heads, but definitely need some work to see their full potential.
How big of an engine do you plan to put these on?
Old Jul 18, 2004 | 09:26 PM
engineermike's Avatar
No one uses completely unported AFR's. Kinda' defeats the purpose. . .
Mike
Old Jul 18, 2004 | 09:27 PM
atljar's Avatar
Yes running them out of the box is less than ideal.
To answer your question.
The 220s take standard valvetrain setups.
The 227s require offset everything (shaftmount rockers etc) to accomodate the 60/40 valve spacing.
Old Jul 20, 2004 | 04:09 PM
Just curious, thats all guys...
I know NOTHING about heads...
Thank you for the replies !
bunker
Aug 21, 2015 10:21 AM
whitehooptie
Aug 10, 2015 07:02 AM
4586
Aug 2, 2015 01:45 PM
realistyc
Jul 28, 2015 07:32 PM
Catmaigne
Jul 14, 2015 05:17 PM
