difference in 2.5 or 3 inch true duals on heads and cam car?
Old Oct 31, 2005 | 07:44 PM
red96z's Avatar
would one be better than the other ? or is it than u run one or the other depending on fit lowered vs stock height vs drag spring ?
Old Oct 31, 2005 | 08:40 PM
red96z's Avatar
Re: difference in 2.5 or 3 inch true duals on heads and cam car?
better yet what power range constiutes 3 inch over 2.5?
Old Oct 31, 2005 | 10:09 PM
Evil Eric's Avatar
Someone was discussing exhaust flow volume and i thin that 2.5 true duals were not restrictive unless you were making >800hp
Old Nov 1, 2005 | 12:25 PM
red96z's Avatar
can anyone back this up ?
Old Nov 1, 2005 | 02:48 PM
Mindgame's Avatar
2.5" duals good past 800 hp? Don't think so.
I'd switch to 3" once you get to ~425+ at the flywheel. 3" should close to 600 fwhp. At the level most of these guys seem to be shooting for (~500 fwhp) then you're going to see a significant hp loss with 2.5".
If you look at dual exhaust cars that GM has built you can see a few trends.
For instance, the GTO ~340 fwhp uses a 2.5" dual exhaust system. It does vary along the way and is 2" in some areas.
The new Z06 at 505 fwhp uses a 3" dual system. Probably could support close to 600hp with that system but a 2.5 incher would definitely cost some hp... even for a stock car.
If you start getting real serious at 600+ hp then oval exhaust is the only way to fly if you want ground clearance. That's what I'm running on my car right now but it wasn't the easiest thing to put together.
-Mindgame
Old Nov 1, 2005 | 03:08 PM
roadtrip120's Avatar
Got any pics, of the oval exhaust???
Old Nov 1, 2005 | 03:20 PM
SS MPSTR's Avatar
At what point do the 2.5" duals become a significant hinderance? Does the design of the system have any influence on this 'cut-off' point? Muffler design too? IMO, it seems like a few variables need to be defined, for each application, before a determination can be made.
Old Nov 1, 2005 | 03:45 PM
Mindgame's Avatar
SS,
Those are really good questions and I meant to say something about that in my post but lost the thought before I made it to the end. Old age I guess.
Absolutely right about the mufflers. Put a bad muffler in the system and you have a new restriction point. I would only use straight through mufflers like the Borla XR1, Magnaflow, Dynomax Ultra or Bullet, Straightline Performance, etc..
The closer the muffler is to the headers, the more it's design will influence the power losses. The smoother the bends in the system, of course, the better. Line 1 of this paragraph applies to the bendy sections too.
As for cutoff points, there aren't any hardcore #'s. The losses will be proportional to the engine's output. I did see a 66 Nova gain ~5 rwhp, 8 lbs-ft torque with a change from 2.5" x-pipe setup w/bullet mufflers to a 3" x-pipe with new 3" bullets and nothing else. All the piping was from Summit and everything looked, to my eyes anyways, to be the same. Car made ~390 hp at the rear wheels. I would have liked to look at the average #'s but this was a dyno day car and I didn't know the owner well enough to ask for his printout.
edit: My #'s were off on the peak hp & tq
-Mindgame
Old Nov 1, 2005 | 04:06 PM
Transamdriver's Avatar
Originally Posted by roadtrip120
Got any pics???
My 3" true dual setup with 16" Dynomax bullets.
http://www.auburn.edu/~doddsam/td1.JPG
http://www.auburn.edu/~doddsam/td2.JPG
http://www.auburn.edu/~doddsam/td3.JPG
http://www.auburn.edu/~doddsam/td4.JPG
Old Nov 1, 2005 | 05:33 PM
Lonnie Pavtis's Avatar
Based on a design discussion I had previously with Flowmaster, I was told 3" duals become a beneficial addition over 450hp (flywheel). Below this 2.5" is generally enough on a street car.
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Queens94z28
Nov 20, 2014 06:03 PM
RedLineRev
Jan 23, 2003 03:51 PM
NED4SPD
Sep 16, 2002 10:45 PM
