Diff vs LT-1 through the years vs impala LT1
Old Nov 20, 2006 | 03:30 PM
JCS30TH's Avatar
Is there any source out there regarding the differences in model year LT-1s from the Fbody vs b body's? outside of the typical, distributor, maf fuel rail, cast iron heads?
Old Nov 20, 2006 | 05:06 PM
sbs's Avatar
sbs
Yep. It's called "search"
Old Nov 20, 2006 | 05:14 PM
transAMdriv3r's Avatar
93 had non vented opti-spark...where as in 95 they changed to vented-opti spark.
93 speed density...94 and up...MAS air
93...sequential fuel injection...94 and up had multi-port fuel injection
93 had 19lbs injectors...and 94 and up had 24 lbs injectors...
the impalas, caprices and roadmaster had iron heads
Old Nov 20, 2006 | 06:04 PM
JCS30TH's Avatar
yea, I know all that as above, I was referring to things like the front cover, accesory drives ect?
Old Nov 20, 2006 | 06:05 PM
96capricemgr's Avatar
The shortblocks are the same given similar year 94s both b-body and f-body are likely to have "pink" rods. The b-bodies ALL got the vented opti setup even the 94s, the cam was a little milder and the iron heads outflow MOST of the aluminums. The power difference can probably be attributed more to the 87 octane tuning and grandpa quiet intake and exhaust on the b-body than the cam.
Old Nov 21, 2006 | 11:35 AM
Try this article from some added info:
http://www.automotiverebuilder.com/ar/ar99928.htm
That was just plain nasty.
Old Nov 21, 2006 | 12:05 PM
Sweetred95ta's Avatar
Originally Posted by 96capricemgr
The power difference can probably be attributed more to the 87 octane tuning...
I looked at the timing for a Caprice, and I couldn't believe how retarded (as in opposite of advance ) it was. It was like 8-9* in spots. I bet it really wakes the car up to get a custom tune.
Old Nov 21, 2006 | 04:46 PM
sry, i didnt fully read your post
Old Nov 21, 2006 | 05:59 PM
Yeah a good tune makes a world of difference. Consider though too the heads are different and even given the same cam may want different timing than the f-body got.
Old Nov 21, 2006 | 07:36 PM
CamaroSS30thAnn's Avatar
arent the water pumps different to
Old Nov 21, 2006 | 07:43 PM
Jim D's Avatar
The crank snout is different too...different lengths...
And yes the water pumps are different
The WP differences are heater circuit related.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ddr698
Jan 9, 2015 10:05 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
