Dies after idling at 2k
Old Apr 9, 2007 | 11:15 AM
Mortify's Avatar
I drove my car to work this cold morning (at work now) and i noticed that it was idling high whenever I put the clutch in or put the gearbox in neutral, it would always be above 1500 and below 2000 while I was rolling, but once I came to a stop the idle would become normal, I thought that it was just because it was a cold start, but when i go to park the 'bird, and i actually stop, the idle went down to normal for a about 5 seconds and then proceeded to die on me... I had no time to look anywhere yet, possibly on my lunch.
Also, when i tap or step on the throttle, it is like it chokes or hesitates then jumps up, and back down to the abnormal idle RPM.
What could be the problem?
Old Apr 9, 2007 | 12:54 PM
Mortify's Avatar
need help!
Old Apr 9, 2007 | 01:38 PM
transAMdriv3r's Avatar
sounds like a iac motor
Old Apr 9, 2007 | 02:00 PM
Mortify's Avatar
what is a iac motor?
Old Apr 9, 2007 | 02:09 PM
Old Apr 9, 2007 | 02:14 PM
Mortify's Avatar
any way of repair, or should I just replace it?
Old Apr 9, 2007 | 02:23 PM
usually they get carboned up and get stuck, might as well try and clean it with some carb solv and try it out. a new one is about 60 bucks so this may save ya some money.
95_Z28/SS
May 20, 2015 01:23 PM
andrewcapps82
May 19, 2015 10:11 PM
beltrunner
May 17, 2015 10:18 PM
Chet1185
May 10, 2015 09:24 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
