Dielectric grease
Old Jul 5, 2003 | 06:15 PM
1msfyter's Avatar
Dielectric grease
Yes or No? To use on the plug boots(inside)
Will it help?
Old Jul 5, 2003 | 07:31 PM
Use it sparingly on the inside of the boot. It will make the boot easier to remove and help prevent any spark leakage to the surrounding metal.
Old Jul 5, 2003 | 08:34 PM
1msfyter's Avatar
gotcha. gonna give it a try monday.
Old Jul 6, 2003 | 01:03 AM
95Blackhawk's Avatar
Why sparingly? I used it liberally and have great results. Just wondering if I am doing something wrong.
Old Jul 6, 2003 | 01:15 AM
Fatdog's Avatar
Cool
I always use a generous amount on the plug itself,just incase I miss something,but I use a Q-tip to saturate the inside of the coil wire.My02
Old Jul 6, 2003 | 02:24 AM
revtime's Avatar
That is what I did, just a little dab in the spark plug boots.
Keeps em from stickin and tearing the boot up. I learned this on my last set of wires, they were on there for about a year, went to pull some plugs and boots came apart cause they was stuck to the plugs.
Old Jul 6, 2003 | 07:56 AM
Because all you need to do is coat the inside of the boot. Using more is not really going to help more and just wastes grease.
If what you are doing works, then don't worry about it.
Old Jul 7, 2003 | 11:32 AM
PGR's Avatar
PGR
Dielectric grease is also great for conditioning rubber trim, such as door, window, trunk and t-top seals. Check your owners manual, I believe it specifies it there.
30th Anniv Z28
Aug 1, 2015 10:39 AM
GetaZforgetGT
May 10, 2003 07:09 PM
96z
Apr 22, 2003 11:39 AM
scoobysnax83
Apr 2, 2003 10:43 PM
Ray66
Nov 7, 2002 09:01 PM
