Did my water pump go bad?
Old Dec 17, 2004 | 12:19 PM
Inutero's Avatar
car has 108,000 miles, water pump has never been replaced.
I was in traffic last night (40 degree weather) and steam started comming out from under the hood. The temp gauge still said the car was not over heating. So once traffic started moving, I noticed my power stearing had stopped working. Once I got to about 2-3 mph it came back though. I pulled over and called my dad and he came and traded vehicles and took my car home. Are these symptoms of a bad water pump?
Old Dec 17, 2004 | 01:15 PM
Inutero's Avatar
Re: Did my water pump go bad?
could it just be a leak? My dad was able to drive the car home fine with no problems.... I dont think he could drive ti if the water pump had went bad.
Old Dec 17, 2004 | 01:28 PM
dmoor88's Avatar
well jack up your front end and see if its leaking onto your opti.
Old Dec 17, 2004 | 01:55 PM
fesgali's Avatar
That thing about the power steerign not working is probably because the waterpump gave out and started to spew out of the wheep hole. It happened to me, thankful i was in a parking garage and about to park.
But to check just turn the car on and wait for a bit, the fans should turn on without the car being hot at all (mine didn't even get to 170 mark). Then water will start pouring from under the waterpump. Thats when you turn it off and order the Meizere
Old Dec 17, 2004 | 02:11 PM
Compstall's Avatar
CSI is cheaper.
Old Dec 17, 2004 | 02:22 PM
Inutero's Avatar
Well I went out and checked, and I noticed the bleeder screw close to the intake elbow was about a full turn loose for some reason... the intake elbow had some coolant on it. I dunno if this is where it was leaking from last night. Maybe this coolant somehow made it to the power steering box? I also let the car run for about 8 minutes after I tightened the screw, and nothing leaked. the temp even got up to about 220-230, im guessing because I lost so much coolant last night, and I still didnt see the water pump leak anything.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
Zone
Jul 29, 2002 07:43 PM
