did i mess up my optispark timing
Old Sep 1, 2006 | 06:31 PM
Jditlfm's Avatar
Hello I just the opti replacement on my 95 lt1 and now it wont start, I sounds like the timing is way off because I know its firing because it kind of backfires but only it blows air through the throttle body and not the normal Pop sound. When I put it in I made sure it was on the right slot and seated it by hand then tightened bolts as far as I could tell. Did I do this wrong because I didn’t do the cylinder #1 at TDC method. I also broke the opti wiring harness pretty good so im not sure if that’s the problem because at first it wouldn’t even fire but now it dose, I just had to press it in more. I already ordered a new one. Thanks for the help guys
Old Sep 1, 2006 | 06:33 PM
Re: did i mess up my optispark timing
Hard to say. You might have to take it off and check the alignment to the cam dowel.
Old Sep 1, 2006 | 08:01 PM
Jditlfm's Avatar
I riped it all back apart what am i looking for on this one anyone got a good method of setting this up right?
Thanks guys
Old Sep 1, 2006 | 08:08 PM
sleeperMULLET's Avatar
Put some marks with black marker on the timing cover where to dowel pin is, and mark the opti where to dowel slot is and just line up those marks since its hard to see in there. Make sure you have the plug wires ordered correctly.
Old Sep 1, 2006 | 08:32 PM
Jditlfm's Avatar
ok i am pretty sure its just that harness because its pretty messed up and it got a little better when i played with it and after takeing theopti off and reinstalling it looked like everything i had was right. Im am pretty quick at getting everything torn down, took me 20 min from start to having everything in my hands and plug wires labeled.
Old Sep 1, 2006 | 11:01 PM
OBE1 95Z28's Avatar
Here's a photo from Shoebox's site:
http://shbox.com/1/opti_back.jpg
RUENUF
May 25, 2016 08:10 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Gtpguy
Jan 26, 2015 04:50 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Injuneer
Dec 15, 2014 09:36 AM
