belt size for a/c delete w/ march pulleys
Old Oct 27, 2003 | 08:11 PM
bigde4u's Avatar
I did a search but couldn't find the info i need. I know the stock belt works with just the a/c delete but will the stock belt also work if you have march underdrive & alt. pulleys? I'm trying to find out if some has done this with the aftermarket pulleys and if they did what size belt did they use. If you have a belt part # i'd appreciate that too. thanks
derick
Old Oct 27, 2003 | 09:11 PM
billygoat's Avatar
wondering the same thing//////////// anyone???????
Old Oct 28, 2003 | 11:48 AM
bigde4u's Avatar
someone has to know this. TTT
Old Oct 28, 2003 | 12:55 PM
GREGG 97Z's Avatar
I have the March underdrive crank pulley but I'm using it with the stock alternator pulley. I got a new belt when I installed the pulley, it was an inch or two shorter than the stock belt, not sure of the exact size though. When I did the A/C delete pulley the same belt worked, it was a little looser with the A/C pulley but the tensioner took up the difference. I'd try your belt out with the A/C pulley, it will probably work fine. If not just take it to a parts store with you and find some thing slightly smaller.
Old Oct 28, 2003 | 05:14 PM
bigde4u's Avatar
thanks for the info i'll give it a try with the belt i have now and see how it looks then go from there.
HectorM52
Jul 30, 2017 11:46 AM
HarleyZ28
Oct 5, 2015 06:23 AM
Jason Short
Jan 19, 2015 06:34 PM
Compstall
Sep 9, 2002 02:16 PM
