DETAILED instructions on actual fuel pump replacement ? NOT trapdoor walkthough
Old Jul 11, 2005 | 05:43 PM
  #16
Racetronix's Avatar
Re: DETAILED instructions on actual fuel pump replacement ? NOT trapdoor walkthough
Originally Posted by rmackintosh
...speaking of that....I saw on the ThunderRacing website....your dealer for LT1 systems...there is listed a "wiring harness" if I remember right....would this be the "rest" of the kit you supply that I could just add to my Walbro and get the benefits of your system?
...I have the manual, and hate opening the thing after rewiring the entire car when I converted it to a race car, and spent about a month in that CONFUSING mess....
Not to mention, I don't know how relevent the manual is going to be in hooking up an AFTERMARKET pump to a "stock" system.....
The pump and harness installation are covered in our manuals. Removing the tank and all the parts to get it out is something that is covered in the GM manual. If you have made alterations to the vehicle which would affect the tank removal procedure then the GM manual can be used as a good guidline.
Old Jul 11, 2005 | 05:59 PM
  #17
rmackintosh's Avatar
....yes, but is the harness available separately like I asked about Thunder?
May not matter if it was designed to interface with a complete stock environment as the wiring of my car is highly modified at this point...
Here is a start that I have stumbled on....not much for tips/description, but lots of big pics....
Fuel Pump Install Pics
Old Jul 11, 2005 | 06:27 PM
  #18
Racetronix's Avatar
Yes, the harness is available by itself. P/N RX-FLT1-FPWHG-2
RiverMutant96
Jan 30, 2015 09:21 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
