Despirate Help With My A/c Needed
Old May 28, 2004 | 06:47 PM
jasons93z's Avatar
Ok, its about 100 outside and my ac compressor desides not to turn on. I had just recharged it. I tested the compresser and it is still good. It has enough coolant in it, but the clutch will not engage. I tested the relays. What else could it be, it has to be electrical.
Old May 28, 2004 | 07:02 PM
OBE1 95Z28's Avatar
The PCM monitors AC "freon" pressure; if the pressure is too low, the compressor won't come on. You can verify pressure readings with a PCM scanner. You can also check the compressor signal connector in case it's loose/dirty.
Old May 28, 2004 | 07:11 PM
jasons93z's Avatar
how can i see if the pressure is too low because i dont have a diagnostic tool. Also, when you add coolant, is it supposed to keep on leaking out until you put the black cap back on?
HectorM52
Jun 23, 2016 08:42 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
