in depth AC questions
Old Aug 17, 2003 | 02:46 PM
TA Dreaming's Avatar
well i know i have problems with my AC. sometimes i think its just freon other times i think it might be the switches. anyway i need to know what the gauges should read. weve got them at work and well im not that good with AC systems. also if they numbers arent right could i get some possible reasons as to why they are off? thanks Trey
Old Aug 17, 2003 | 10:07 PM
anyone?
Old Aug 17, 2003 | 10:31 PM
A/c pressures
Old Aug 17, 2003 | 10:37 PM
thanks shoebox. ill check it out and see whats up. im hoping its not freon but maybe thats easier than an electrical problem. Trey
Old Aug 18, 2003 | 06:36 PM
ok well i hooked it up today and it was at 30 and 225. it was int he eighties with high humidity. i only looked at the gauges and according to that chart im in the good, but the ac just doesnt workas well as it us3ed too. im talking a few months ago too. i goes through flashes of cold at first. ill be cruising and the air is cooler and that just outside air but itll blow real cold for a few seconds then quit. i thought it was freon but sometimes it didnt do that. sometimes it worked fine. and yes the clutch is turning on and off. any ideas. thanks trey
Old Aug 18, 2003 | 09:17 PM
Harpoon Flyby's Avatar
There is a low pressure switch on the low side line (the cold one) before the accumulator/drier (silver can thing on passenger side of engine). You can check this switch to see if its opening. Try wiggling the wire while the a/c is on. Hope this helps.
HF
Old Aug 18, 2003 | 09:40 PM
thats a good point, but can the switch be bad if the pressure is good? trey
Old Aug 18, 2003 | 09:43 PM
The switch could have a short/open condition.
HF
Old Aug 18, 2003 | 09:48 PM
ok thanks ill check it out in the morning. trey
Victor Lamb
Aug 26, 2017 02:52 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
gh0st
Sep 5, 2002 07:54 PM
MilkyClr69
Jul 29, 2002 10:01 AM
