DELTEQ users, where is your shift light hooked to?
Guest
Posts: n/a
If you are useing a shift light with your DELTEQ, where are you hooking up the shift light for its signal. I have a MSD shift light, and it seems to use the coils negative side on non standard ignitions. So, would hooking up to one of the coils using there , DELTEQs manual, work?
http://www.delteq.com/Rev5c_Vette.pdf page 15 fig 9.
Re: DELTEQ users, where is your shift light hooked to?
or you can tap into the tach signal from the PCM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
