DELTEQ users, where is your shift light hooked to?
Old Jun 1, 2005 | 11:54 AM
Steves396lt1
Guest
Posts: n/a
If you are useing a shift light with your DELTEQ, where are you hooking up the shift light for its signal. I have a MSD shift light, and it seems to use the coils negative side on non standard ignitions. So, would hooking up to one of the coils using there , DELTEQs manual, work?
http://www.delteq.com/Rev5c_Vette.pdf page 15 fig 9.
Old Aug 22, 2005 | 07:13 PM
Steves396lt1
Guest
Posts: n/a
Re: DELTEQ users, where is your shift light hooked to?
ttt
Old Aug 22, 2005 | 08:28 PM
Dave89IROC's Avatar
in that figure, use the wire that says to tach, near "see note 2" and "see note 3"
or you can tap into the tach signal from the PCM
Old Aug 22, 2005 | 10:25 PM
Steves396lt1
Guest
Posts: n/a
Jlo
Feb 3, 2015 09:41 PM
Ari G
Dec 11, 2014 03:21 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Krab
Aug 5, 2002 12:08 AM
