LT1 or LT4 heads?
LT1 or LT4 heads?
I was told they were LT4s but i am not sure, the casting number is 10207684 or 10207643 i am not sure on the last number. the only other number on the heads i 5348. Any help is appreciated.
Re: LT1 or LT4 heads?
Originally Posted by Black6spdZ
anybody?
http://www.grandsportregistry.com/lt1vslt4.htm#HEADS
The most noticible difference is the ridge below the valve cover on the intake side. On the LT1 it is thick about 1/2", for the LT4 its only about 1/8".
As far as the extent of potential, LT4 are better. You can do more with the raised ports and other good stuff.
TFS has been making good castings but their heads have a larger combustion chamber which is good for boost motors, but not as good for N/A motors unless you mill them.
I plugged 10207643 into a google search, and came up with this link:
http://www.chevy-camaro.com/SBCheads.asp
It shows:
"10205245 1993 350
10207643 1994-96 350 "
That would suggest its an LT1 head, since the LT1 didn't exist in 94.
It shows:
"10205245 1993 350
If 10207643 is the casting number for LT4 heads, my 1995 LT1 came stock with them!
95chwagon
Jan 13, 2015 09:19 PM
